Drive your car around until it has hit operating temp with the thermostat open, head home then park it.
Take both leads off battery and depress your brake pedal to get all electrical current from the vehicle
Wait 20-30 mins, grab a beer and jump on the boosted forum
When the time is up, reconnect the battery and proceed with the following.
Or you can disconnect the battery and turn the headlights on, that will achieve the same result
DO NOT TOUCH THE ACCELERATOR DURING THIS PROCESS ONCE THE KEY IS TURNED ON
To calibrate the ECU and the correct idle speed, proceed with the following (each step must be done for a min 2 minutes)
HANDBRAKE ON and start the car.
- Neutral with all electrical loads OFF
- Neutral with all electrical loads ON
- Drive with all electrical loads ON
- Drive with all electrical loads OFF.
If doing this in a Manual, place the car into 1st with clutch depressed (not 100% sure with a manual)
Throttle Position Sensor (setup)
- To set the closed throttle reference position, place the transmission in Drive, Air con off, and let the engine idle for 2 minutes.
- To set the wide-open throttle reference position by turning the engine off- but leave the ignition switch to the "ON," position, (dash warning lights should be on) then press the accelerator pedal to the floor and hold it their for 1-2 minutes.
- Then put into PARK and switch off the ignition.
- Drive the vehicle and check for proper shifting patterns.
Should work for all auto Falcons EA-BA
The instructions provided should stop the car running like a pig for 50-150 km until the ecu re-learns everything.
