ENGINE
250 xflow
265 hemi rods
offest ground crank, nitraded
main stud and head stud kit
o-ringed block
SPS forgies
ARP rod bolts
custom scraper tray
high energy sump
JP oil pump
Double row timing chain
Custom wade hydraulic cam
ported, polished alloy head
yella terra roller rockers
custom valves
isky dual valve springs
port matched factory inlet manifold
Rochester 1000cc injectors
Bosch 044 external pump
Pierburg internal pump
surge tank
Barry Grant fuel reg
Wolf 3D ECU
TURBO and EXHAUST
Garrett T66 1.32 ex .7 inlet
Custom exhaust manifold
3.5in Dump pipe, to 3in sinlge system with single muffler
48mm External Wastegate, with screamer pipe
TRANS
KEAS C9 700hp
TCE 3000rpm converter
B&M trans cooler
Standard tail Shaft
WHEELS and SUSPENSION
19x8in BF GTP
245/35/19's
Nolathane bushes throughout the car
Boxed upper and lower rear control arms
King spirngs front and rear, have been modified a bit
90/10 shocks front
50/50 shocks rear
